And here the log file:
Rhino_WIP_20160901152810.zip (3.8 KB)
-C-H-A-R-L-E-S-
Strange. That log doesn’t have much useful in it, but I’ve passed it along to some folks that may be able to help decipher it. I’ll let you know if I find anything out.
Does restarting your computer and then installing work?
@Charles We are using some tools from FireGiant to build our installers, and I’ve forwarded your logs to them. Here are the questions they asked:
Usually, when the MSI engine immediately fails, it’s due to problems accessing or opening the package. But that returns a different error code (e.g., 1619 ERROR_INSTALL_PACKAGE_OPEN_FAILED). So we’re not sure what’s wrong in this case. Does the same error occur again if you re-run the bundle? Does this error happen every time? Have you seen it on OSes other than Windows 10 Anniversary?
Can’t tell… I have no other PCs.
Did you try restarting your computer?
Restart helped.
The install issue comes up on every new WIP version.
This was also the case on pre-1607.
-C-H-A-R-L-E-S-
