The title is fairly self explanatory. The -Rebuild
commands allows for more control/options over the standard Rebuild
command. Are there any other commands where adding the -
will give the user more functionality?
the - dash will only suppress the dialog box, you’ll retrieve same functionality in command line , the SelectMasterCurve is on right click, just placed alternatively
There are two uses for the dash - one is to suppress the dialog, which it always does, the second is to add additional command line options to certain commands. An example of the second would be the -ViewCaptureToFile, where the dash version gives you the option to change the pixel dimensions. I don’t have a list of all the commands that do this offhand.
–Mitch
