spb
(Steven Burzinski)
1
- Run _ExtendSrf
- Pick an edge of a surface whose output should be different for either value (Line/Smooth) of Type.
- Toggle the Type option to the other value.
Neither the preview, nor the resultant geometry matches that of Type’s setting. Instead, the value of Type before the edge was selected is used.
This occurs in both V6 and the WIP.
pascal
(Pascal Golay)
2
Hi Steve - I see that the preview does not update but here, so far at least, the result does pay attention to the setting change.
spb
(Steven Burzinski)
3
I now see that what you found is true when surface is untrimmed. For trimmed surfaces, both preview and result are incorrect.
pascal
(Pascal Golay)
4
Got it, thanks.
RH-58490 ExtendSrf preview and result
