When i finish editting the block,it will trigger the delete objects event.Why?What’s something wrong with it?
Hello- are you concerned because objects are deleted or because some code that you run sees a delete object? That happens all the time behind the scenes - if the behavior does not look wrong in Rhino, I would not sweat it…
Only when I open the block editting,and then close the block editting,this event will be triggered.
Hi -
As Pascal wrote, that’s normal behavior.
If you are trying to solve a problem, please describe the issue in detail and provide the code that causes the problem.
