Advanced Options: Wire thickness has a weird number
I just played with some advanced settings and figured out that choosing a value of 0,5 for the wire thickness returns a weird number in the field.
P.S. Is there a way to control the wire thickness of the surfaces globally, separate from the curve thickness? The “WireThicknessScale” setting affects both object types, which is limiting. Ideally, these should be separate settings.
The display settings can control certain curves and isoparms separately.
But, different display engines have different properties.
Here is the surface edges and isoparm thick and the curve thin coming out of Shaded mode:
Indeed individual settings for the curve and isocurve thickness are needed. I can’t work with thick isocurves while the curves are as thin as a hair. I would rather prefer 1 pixel wide curves and isocurves.
P.S. Rhino 5’s consistent wire thickness and perfect anti-aliasing were on another level…
I do have individual control over UV and curves separately in the shaded mode:
What mode are you using to modify from? There are technical modes that have differing controls.
I usually work with my custom modes, but currently I run a stock Rhino 9 BETA to avoid the bugs that I faced with my display modes imported from Rhino 7. I started several topics regarding those issues about a month ago.
