Adjusting spacing when using curve array
Hello, i’m very new to grasshopper and rhino 7. I was wondering if anyone knows how to adjust the spacing when using curve array? An example grasshopper setup would be helpful.
dear @ashmikagp
the spacing of curve array is based on the number.
if you increase the number → more space and vice versa.
internalize (right mouse button on input parameter component) your geometry and post the .gh file if above info does not help.
kind regards -tom
The number only seems to change the number of components not the spacing in between the components. I am interested in changing the spacing in between.
… you may want to share / post / upload your .gh file please.
higher number - more objects - less space between
