Adjusting geometry breaks array
I’m trying to duplicate an extrusion using Curve Array in GH, and finding that adjusting the geometry of my extrusion breaks the array:
Before adjusting geometry:
After:
This is using R8. Any ideas?
3. Attach minimal versions of all the relevant files
:man_facepalming:
curve-test.3dm (119.1 KB)
curve-test.gh (5.3 KB)
Hi Andrew -
Rhino 9?
At any rate, when you select the first object in Rhino, the command line states:
1 closed extrusion added to selection.
When, in Rhino, you modify that object by moving an edge, the command line will read:
1 closed polysurface added to selection.
In Grasshopper, you use the Extrusion parameter to reference the original extrusion object, but when this is modified and becomes a brep, that parameter won’t be able to reference that new object. Use the more general Brep parameter instead:
Lol… whoops, wasn’t watching what I was typing.
thanks.
