Could we have a factor value box in Adjustable Curve Blend please? Like the one in Blend Srf. The idea being that one could use the same factor value on different Blend Curves in the same model.
Phil Cook
simplyrhino.co.uk
Phil Cook
simplyrhino.co.uk
I fully endorse this request. To attempt to get equal control on both end controls of the blend is nearly impossible as it stands now.
Robb, if you hold Shift while dragging the points in the BlendCrv command, both ends will pay attention.
Thanks, Pascal, I’ve been using Rhino for so long I likely forgot that command extension, I am humbles as the total dork I am…cheers, Rob
But when I first adjust the handles individually, for example the one a little longer the other a little shorter → and then I may want to lengthen / shorten both handles together maintaining the individual proportion, it is not possible.
As soon as I hold Shift while dragging the points, I lose the initial adjustment.
It would be very nice if the handles could be moved on both sides simultaneously, by holding Shift and dragging the first point on the curve.
Yep, thanks, this one has been on the heap for a while now
http://mcneel.myjetbrains.com/youtrack/issue/RH-28502
