Adjust the peaks and valleys generated by LunchBox
How can I accentuate the peaks and valleys generated by LunchBox? Currently, I am adjusting the UV values to achieve this (green circle), but some areas remain too smooth (white circle).
Is there a way to customize/control the amplitude of the peaks and valleys manually? Or is there a method to make the smooth areas look more ‘folding’ (more angular or creased)?
I’m thinking of dropping LunchBox and just building the logic from scratch to get better control. Any other suggestions?
I used Ngon and Lunchbox.
too smooth.gh (79.0 KB)
Do this first then share that file :slight_smile:
Lunchbox/Ngon most likely not needed here.
