Hi, in the .3dm file attached I use the NetworkSrf command to form the envelope of a hull from contour lines. I would like the surface angle of the stern (the rear) to be rectangular as in the contour. But even with the smallest value of edges curves in the command parameters it doesn’t match. Do you know a simple way to do this?
Hi Virgile - - NetoworkSrf will not make a kinked surface. If you want a hard corner there, you’ll need some other surfacing tool that can make a polysurface.
Should the hull be symmetric? Your curves are not symmetric. The centerline curve is not planar.
When creating a symmetric hull it is usually simpler to create one half of the hull and then mirror it. Also it is usually simpler have the center line of the hull on one of the World coordinate planes.
