if one wall of two adjacent zones touch each other, are they considered two walls in grasshopper or are they read as one single interior wall by grasshopper and energyplus for energy simulation?
Hi @Maryam_Aman,
For energy simulation you need two walls. For more about this topic you can better go to the Ladybug forum. Ladybug Tools | Forum
For downloading this plugin you can go to:
And here you can find example files for setting up a model: lbt-grasshopper-samples/samples/honeybee-energy at master · ladybug-tools/lbt-grasshopper-samples · GitHub
Hi @Erik_Beeren
Im using ClimateStudio for energy simulation, do you have any suggestions for that?
Thanks, Maryam
Hi @Maryam_Aman
if you install ladybug 1.5 it has a component intersect mass. You can use this to to make a correct model for energyplus.
