G’day everyone,
A user has exposed my poor scripting skills. I’m just beginning the debugging and can’t see anything that looks to be responsible.
A surface has thickness usertext attributed to it, not attached to geometry so it should be resilient. A “property checker” confirms that the thickness (and other attributes) is assigned. Another script (below) changes the objects colour (rs.ObjectColor) based on the thickness attribute, but in the process nukes all the usertext attributes (thickness, name, etc…) of some of the surfaces.
While debugging, running this script once seems to work, nothing gets nuked and the colours get changed properly. But if I run it again straight away some of the parts are nuked, but not all of the ones with the same thickness. Actually, it looks like the usertext gets nuked on the first run, but is only apparent after the second run.
I have tried to avoid adding any usertext to geometry because I don’t want it to be volatile, but it may’ve slipped in over the intermittent years of development. But objectcolor change should not nuke geometry usertext.
It isn’t a particularly complex script.
GetObjects
Loop through the objects
GetUserText
AddMaterialToObject
ObjectColor
MaterialColor
Any thoughts?
import System
from System.Drawing import Color
def colourparts():
strSurfIDs = rs.GetObjects("Please select surfaces to colour.", 24, True, True)
if not strSurfIDs: return
strAttribute = "Thickness"
if not strAttribute: return
for strSurfID in strSurfIDs:
strValue = rs.GetUserText(strSurfID, strAttribute) #Object Attribute Value
index_Material = rs.AddMaterialToObject(strSurfID) #In case viewport is rendered
if strValue == "3":
color = Color.LightCoral
elif strValue == "4":
color = Color.Green
elif strValue == "5":
color = Color.HotPink
elif strValue == "6":
color = Color.Olive
elif strValue == "8":
color = Color.Purple
elif strValue == "10":
color = Color.RoyalBlue
elif strValue == "12":
color = Color.DarkSeaGreen
else:
color = Color.Black
objColour = rs.ObjectColor(strSurfID, color)
matColour = rs.MaterialColor(index_Material, color)
if __name__ == '__main__':
colourparts()
Coloured by layer
After first run of colour by thickness script (correct colour, but all usertext of affected parts is nuked).
After second run of colour by thickness script (incorrect, grey part has had all usertext nuked).
Why would the attached script nuke any usertext?
cheers,
Nick
