AddLoft Tangency in script
I’m trying to generate a family of models with RhinoPython. The main body of my object is a loft through a series of curves.
I need to add an additional feature that is a 2nd loft, starting at the edge of the 1st and tangent to the 1st. Any way to control the tangency of the loft? I also can’t figure out how to select surf edges in script.
Help would be greatly appreciated!
thanks.
Hi @brodiej,
The rhinoscriptsyntax.AddLoft method calls RhinoCommon’s Brep.CreateFromLoft static function. There isn’t an option to match start and end tangency.
I’ve added a wish item to the list.
https://mcneel.myjetbrains.com/youtrack/issue/RH-45628
This is item is implemented, you’ll need to pass in the starting and/or ending BrepTrim objects, along with any additional shape curves.
– Dale
RH-45628 is fixed in the latest WIP
