New rhino user here, I have created a skyscraper which I want to add vertical mullions/fins to the facade. The tower tapers from bottom to top as you can see from the attached image. What is the best way to add these vertical fins/mullions? Use the contour function? I want to make sure these vertical lines will follow the taper curve of the building.
Thanks!
