Hi all, I’m attempting to modify some geometry so that I can 3D print a large file. The geometry must be scaled down to 1/8 scale. The smallest geometry measure at 1/32". So I’m looking for a way to resize these to nearly 1/16" or larger so that the 3D printer can recognize and print the objects and have valid trace lines.
Hello - it’s not exactly clear what it is you want to do - in your example file the surfaces are not joined but assuming they were would you want to simply scale some of the objects, each on its own center? BoxEdit
might help there…
