Adding text into gcode
Hi
Im trying to enter a text for 3d printing in an especific Z.
I would like to put a command to switch on the fans M106 S255 when the valour Z is higher than 1.2, for example. I can’t add the text file sorry.
I’ve searched the forum but haven’t found a solution to something so specific.
Now, I do this manually, opening the txt file and adding this command.
I have try find and replace, but does’t work for me. For this example, I add two spaces. but it’s not necessary.
Thanks!
export.gh (18.0 KB)
3. Attach minimal versions of all the relevant files
added a gh file. I take the points and concatenate data with info.
I am not in a hurry for this solution, since my current solution is to do it manually, but it is impractical
Thanks!!
That wasn’t so hard, eh? Much easier than creating test data by hand :exclamation:
Adding text into gcode_2023Oct3a.gh (19.6 KB)
wow! thanks! @Joseph_Oster
