I’m trying to add options for my plugin in Rhino option panel. I believe I must create a class inheriting OptionsDialogPage, but I get an error message concerning the constructor, and I can’t figure out how to do this. Any Idea?
Public Class MSWOptionPanel
Inherits Rhino.UI.OptionsDialogPage
Public Overrides ReadOnly Property PageControl As System.Windows.Forms.Control
Get
Return New MSW_OptionControl
End Get
End Property
End Class
Thanks @dale, I can’t script because its not from a Rhino Command, but I think I figured a solution: since the option page is actually a windows control, I just have to add it to a windows form.
I have another issue with this option page: when I first open the rhino options, it works fine. If I close them then re-open, my option page is blank. Any idea?
I don’t understand this comment. But if you have added a page to Rhino’s Options dialog and you want to display this page from your application, then just script the _-OptionsPage command using RhinoApp.RunScript.
I thought Runscript had to run from a “script runner” command but it seems it’s not the case.
Do you have any Idea concerning the control not loading when opening for the second time? When I add my option control to a winform I don’t have this issue
