Hi everyone,
I was trying to create a this component using GHpython for creating a Picture Frame and I have met with a dead wall with some issues:
If there is way to achieve the same result without the action of baking the image directly in Rhino?
The AddPictureFrame requires a Plane where the image will be inserted, how to tell it that I need the XY Rhino World plane ?
PS: I have already tried giving it a point and the WorldXYPlane.
Geometry Rhino - Python - Unfinished.gh (11.2 KB)
Thank you in advance
@Nader_Belal, have you tried the ImageSamplercomponent ?
you can set the rectangle in the image sampler. In python maybe this helps:
AddPictureFrameTest.gh (8.2 KB)
_
c.
@clement
Thank you for your quick responce
Image Sampler component is a good option, but it doesn’t serve the purpose I need.
Why I´m getting this error message ?
Runtime error (MissingMemberException): 'ObjectTable' object has no attribute 'FindId'
Traceback:
line 19, in DoSomething, "<string>"
line 26, in script
Probably because you’re not running it in Rhino 6. Rhino 5 does not know FindId
method, you might exchange the following line:
rh_obj = Rhino.RhinoDoc.ActiveDoc.Objects.FindId(frame_id)
with this for Rhino 5:
rh_obj = Rhino.RhinoDoc.ActiveDoc.Objects.Find(frame_id, True)
_
c.
@clement
I have learnt a lot with the example you have sent me, and I would like to know:
Why did you use Bitmap & not Image Class ? (I´m asking cause I’ve checked them and couldn’t understand)
What is the function of Rhino.RhinoDoc.ActiveDoc class?
I was just remembering that i could then get the width and height quickly. You can do the same using the image class of course:
image = System.Drawing.Image.FromFile(file_path)
w, h = image.Width, image.Height
If you’ve scripted using the python built in editor (_EditPythonScript
) in the past, the method is used instead of scriptcontext.doc
_
c.
thank you @clement for your script.
