Adding model line error: The multiplicities of other interior knots must be at most degree - 2
Getting this error when attempting to add model lines (closed curves) using the AddModelLine.ByCurve component.
As far as I know this is related to Nurbs handling of curves but it seems over my head - I’ve ensured there are not duplicate lines causing this error and each straight segment of each curve is made up of simply 2 endpoints. Any help is appreciated.
Would you mind shareing the definition so I can run tests here? Thanks!
Rhino and Ghop attached, thanks for taking a look @eirannejad . 200115_model_RI.3dm (480.5 KB) 200116_brep_plane_at_level_RI.gh (14.4 KB)
Hey @dburpee
Seems like there is an issue with the component trying to create periodic curves. I have filed an issue:
Thank you for taking a look @eirannejad
To be clear - the curves in my definition are non-periodic, correct? They have kinks / hard corners. I found this similar forum post for OpenGl (but it is related to nurbs curves and knot multiplicity. Perhaps the information can be of some help.) https://community.khronos.org/t/knot-multiplicity-greater-than-order-of-curve-erro/62113
