Adding event listeners to three.js objects added to the viewer
Hi, I’m trying to create a transform controls gizmo using three.js objects added to the viewport.
This is the provided example for adding three.js objects but how would one go about adding interactions to the three.js object? Three.js Objects
Can you use three.js event handlers with the viewport?
Hello @lopa421,
currently that is not possible. Fortunately, this feature is on our roadmap. I will notify you once it is publicly available.
Cheers, Michael
Hello @lopa421,
we had an internal discussion on this and will try to make more of the three.js core objects (camera, renderer, etc.) accessible. With that, it should be possible to enable something like a three.js gizmo on your own. We will get back to you on that!
Cheers, Michael
