Hi Dale!
Thank you, it’s Crystal clear.
Two more questions (please excuse me, this can save much time). The matter is: extrusion of more closed polylines into one single 3D solid.
An extrusion having two “outer” closed polylines, (e.g. a cross-section ][ or || double angles, or double channels, typical in structural engineering)
extrusion.SetOuterProfile(&curve1, TRUE);
extrusion.SetOuterProfile(&curve2, TRUE); // I guess only first will be kept
Is that possible? I fear not: “If the extrusion already has a profile, the set will fail.”
An extrusion having one “outer” closed polyline and one or more holes (CHS, hollow sections)
I am “a glutton for punishment”
What is it still missing to end extrusion definition (i.e.if I am not using CreateFrom3dCurve)? Extrusion direction and extrusion amount.
More generally, if I see well, the place where to learn this kind of things is “opennurbs_beam.h”? 'Cause I don’t want to disturb placing stupid questions.
If I call only the first two, as I did, I get a crash adding the object.
However I have still some questions, you can reply quickly to many of them just with YES/NO
Extrusion accepts only 1 outer profile so one single 3d object will be generated if profile is closed
Is profile is closed you may add more than one inner profile (holes).
Path is the extrusion path, from start to end. It must not entirely lay over the curve plane.
Its start point must lay over the bottom plane.
Up is used to set a direction. Why? Isn’t it the path to give the direction of extrusion?
The first parameter of SetDomain is not clear…
I am sorry. May be I missed some document with explanations.
Thank you
Paolo
