I want to add a line of control to a nurb surface to be able to pull a sort of
knuckle or cease, think about a BMW 7, see attached file.
The surface itself is a trimmed NUBS with loads of control points! I have upoloaded the file with a projected
line where the knuckle should be situated.
The Knuckle should not extend over the whole lengthe of the surface!
Your valuable helpü is very much appreciated.
surface
Layer name: Flossenstab
Render Material:
source = from layer
index = -1
Attribute UserData:
UserData ID: CE28DE29-F4C5-4faa-A50A-C3A6849B6329
Plug-in: 17b3ecda-17ba-4e45-9e67-a2b8d9be520d
description: User text (1 entries)
saved in file: yes
copy count: 25
Geometry:
Valid surface.
Trimmed surface with 1 hole(s)
NURBS Surface
“U”: degree =3 CV count = 73 (0 <= U <= 7057.53)
“V”: degree =3 CV count = 17 (0 <= V <= 944.923)
Edge Tally:
14 boundary edges
Edge Tolerances: 0.000107224 to 0.00442802
median = 0.000813015 average = 0.000945563
Vertex Tolerances: 0.000107224 to 0.00442802
Render mesh: 1 fast mesh 473 vertices 509 polygons
Analysis mesh: none present
Cease or knuckle.3dm (2.3 MB)
