Let’s say I want to offset a curve but have the cap be larger on one end than the other. Or, have the stroke thickness change at different control points. Is there a way to do this?
Was thinking maybe a plugin or grasshopper. I’ve sketched out what I’m trying to do below.
What a coincidence; I encountered something today where I was wondering the same thing. Any big brains know of an old script or trick to do something like this?
The trick is to extrude the original curve into a surface, use VariableOffsetSrf to offset it with your different values, then dupe the edge of the offset. There are a couple of other workarounds as well. This is also scriptable, someone has probably already done it…
Both options worked well! The pipe and extract isocurve was a little faster, but VariableOffsetSrf seems more widely useful. Thanks so much for the quick replies
