Hello, i want to add button “disable/enable solver” , which loaded automatically when Grasshopper started.
How i can fix this code to make it work?
using Grasshopper;
using Grasshopper.Kernel;
namespace DisableSolver
public class DisableSol
public static void CustomizeUI()
if (Instances.DocumentEditor.Controls[0].Controls[1] is System.Windows.Forms.ToolStrip toolbar)
var SolverButton = new System.Windows.Forms.ToolStripButton("Disable")
ToolTipText = "Disable Solver"
SolverButton.Click += (s, e) =>
if (GH_Document.EnableSolutions == true)
if (SolverButton.ToolTipText == "Disable Solver")
GH_Document.EnableSolutions = false;
else if (GH_Document.EnableSolutions == false)
GH_Document.EnableSolutions = true;
toolbar.Items.Add(SolverButton);
kitjmv
(jmv)
July 30, 2022, 9:10am
2
At first, you can access the toolbar with Grasshopper.Instances.DocumentEditor.MainMenuStrip
And your method should be called in Grasshopper.Instances.CanvasCreated
event. This is to ensure that all UI objects have been created.
jmv
kitjmv
(jmv)
July 30, 2022, 9:19am
3
I just saw your previous message. Automatically add buttons to the toolbar when GHA is loaded? - #4 by seghierkhaled
If it’s the same question, my answer is wrong and I don’t know.
The Grasshopper.Instances.DocumentEditor.MainMenuStrip
provides access to the top level toolbar:
Hi @kitjmv
Thank you, what i want is a permanent button
At this moment i use python script and need place it every time to add the button to the toolbar.
I see in rhino.inside-bricscaf source code ,they call Grasshopper as command with code of the button.
I don’t know how to call the above script when we click Grasshopper button in Rhino.
Thanks again, i just want permanent button
I don’t need the menu
kitjmv
(jmv)
July 30, 2022, 11:39am
6
Seghier khaled:
permanent button
Sorry I do not understand.
Maybe a image is better…
Fixed button like other buttons in the ttolbar
kitjmv
(jmv)
July 30, 2022, 11:55am
8
I assume you are using this model:
try
System.Diagnostics.Process.Start(@Path.Combine(GhBcConnection.DllPath, "Samples"));
catch (System.Exception) { }
specFold.DropDownItems.Add(samplesItem);
if (Instances.DocumentEditor.Controls[0].Controls[1] is ToolStrip toolbar)
var linkButton = new ToolStripButton(Properties.Resources.link)
ToolTipText = "Link with current BricsCAD document"
linkButton.Click += (s, e) =>
if (System.Convert.ToInt16(_BcAp.Application.GetSystemVariable("DWGTITLED")) == 0)
MessageBox.Show("Bricscad drawing must be saved before using Grasshopper");
else
Inside a Rhino plugin:
public class Plugin_Rhino : PlugIn
public Plugin_Rhino () {
RhinoApp.Initialized += OnRhinoAppInitialized;
void OnRhinoAppInitialized (object sender, EventArgs e) {
RhinoApp.Initialized -= OnRhinoAppInitialized;
Grasshopper.Instances.CanvasCreated += CreateGrasshopperUI;
void CreateGrasshopperUI (GH_Canvas canvas) {
Grasshopper.Instances.CanvasCreated -= CreateGrasshopperUI;
Exactly
Looks like i need to create a dll with the second code?
CreateGrasshopperUI …
kitjmv
(jmv)
July 30, 2022, 12:07pm
10
Seghier khaled:
second code?
I don’t know what you call “second code” but you must have a Rhino plugin (like my example to initialize CanvasCreated event) and the Grasshopper plugin
(CreateGrasshopperUI is the name I chose)
Thank you , i will try it
kitjmv
(jmv)
July 30, 2022, 12:55pm
12
Note that your Rhino plugin can reference your Grasshopper project and your CreateGrasshopperUI method can be placed in the GH plugin:
Grasshopper.Instances.CanvasCreated += MyGrasshopperPluginClass.CreateGrasshopperUI;
I don’t understand why we need Rhino plugin (rhp)?
I see many Grasshopper addon have unique buttons loaded automatically.
kitjmv
(jmv)
July 30, 2022, 3:04pm
14
It uses a private grasshopper function LoadGHA
var LoadGHAProc = Grasshopper.Instances.ComponentServer.GetType().GetMethod("LoadGHA", BindingFlags.NonPublic | BindingFlags.Instance);
return false;
return true;
public static bool LoadGrasshopperComponents()
if (_grasshopperLoaded)
return true;
if (LoadGHAProc == null)
return false;
var bCoff = Grasshopper.Instances.Settings.GetValue("Assemblies:COFF", true);
Grasshopper.Instances.Settings.SetValue("Assemblies:COFF", false);
var rc = (bool) LoadGHAProc.Invoke
Grasshopper.Instances.ComponentServer,
new object[] { new Grasshopper.Kernel.GH_ExternalFile(Assembly.GetExecutingAssembly().Location), false }
To be honest, if you don’t understand the Grasshopper loading process, use two plugins.
jmv
kitjmv
(jmv)
July 30, 2022, 3:09pm
15
That said, I really don’t understand.
If you have a Grasshopper loaded, just call the function that creates your menu.
in your first post, an explanation of the error would be helpful
Calling the function is not the problem.
When i run the code, the button added immediately to the toolbar.
But i want the button appears automatically when Grasshopper opened, which mean -maybe- autorun the function.
Finally it works, i find a solution after checking PersistentDataEditor
Disable/Enable Solver, Undo, Redo
Rh-3d-p
(R-d)
July 31, 2022, 9:31pm
19
Hi @seghierkhaled can you created it icon by c# or python? Can you shearing it?
Hi @Rh-3d-p
Check this with python, you can do the same with c#
add remove button.gh (4.9 KB)
