It would be great to have an AddBrace.ByCurve component similar to AddBeam.ByCurve. Or it would be similarly good if I could set the StructuralType when using the AddBrace.ByCurve. Do you plan to do any of these?
Is this still an issue? if so…it is not currently possible the beam by curve is set to structural type “framing”
you could make your own c# component that used the Revit API to create structural framing and set it to the structural type “brace” NewFamilyInstance Method (Curve, FamilySymbol, Level, StructuralType)
Thanks. We did create our own component for braces!
