Would it be possible to add the retrim option to the wonderful _refitTrim command.
in the case of a surface limited on two opposite edges. the command tends to ignore the limit on the other edge
I get around this problem for now by duplicating the opposite edge and then making a limit from the resulting curve
hi kyle.
you mean refittrim on the two opposite sides at the same time?
if so, it is 80% sufficient.
but, what would you say in the case of a surface that has a complex boundary on the other edge?
this is not a very common situation during modeling. but it can be useful.
as in this example in photo.
