Add specific number of Dependent Views
Hi! :wave:
Is it possible to specify the number of dependent views to create?
I know there are plugins for looping in Grasshopper, but I’d like to avoid using any additional add-ons.
Thanks for your help :pray:
Hi Lukas,
You can feed multiple copies of the View you want to create dependents for, like so…
Hi @Japhy,
Thank you so much! I didn’t expect such a simple solution—you never stop learning! :slight_smile:
While testing it, I noticed unexpected behavior in Rhino Inside Revit.
I run the script by clicking a button like this one:
When doing so, I found that the script runs twice when the solver is locked.
However, when the solver is enabled, it works as expected.
Locked Solver
I was able to replicate, thanks for reporting!
