Add Shrinkwrap To Rhino7?
That usually happens when the KangarooSolver file assembly location set is not the same as the one being loaded by Rhino.
This is different if you are using Rhino 6 vs the WIP. For the WIP it is in the location I gave above. For 6, you probably have it somewhere like here:
C:\Users\Daniel\AppData\Roaming\Grasshopper\Libraries
Many Thanks !. It is working right now. It was a wrong kangaroosolver.dll that I was referancing
