Add Room Error
I am trying to bake Room Separation to a Revit File, then use them as room boundary to add rooms. RiR returns this error. Trying to understand why.
Thanks!
Looks good here, you’ll need to provide additional detail (your curves)
TestCurves.3dm (385.1 KB)
Hey Japhy, please see the attached rhino file. It is part of the curves.
I believe its because you have overlapping Room Separation lines.
https://help.autodesk.com/view/RVTLT/2023/ENU/?guid=GUID-BAEDEC9D-BDBA-44A5-B611-BD5802F04A56
after a little curve cleanup stepping through these one by one (disabled tracking) works for most
RiR_RoomSeperation.gh (10.9 KB)
Got it. I tried explode them then delete duplicated lines, but then I thought I wanted to keep the continuous curve to hold Room info. I will just make sure the lines are clean enough. Thank you Japhy.
Its odd though, you can manually place rooms in via the Revit UI on those overlapping lines.
yeah, exactly, even with those baked duplicated lines. I can still place rooms with native Revit operation.
Stepping through and finding a bad one, then delete the previously placed lines and then run just the bad one will work, its the overlap with the others that is causing the failed UV error.
