Add Revision: Revision Date and Revision Description are swapped
I have noticed an issue with the Add Revision component in Rhino.Inside.Revit. Specifically, the inputs for Revision Date and Revision Description appear to be swapped.
When these inputs are connected in Grasshopper, the Revision Date is displayed under the ‘Description’ column in Revit, while the Revision Description is shown under the ‘Date’ column. This behavior seems unintentional and could potentially cause confusion for users.
Could you kindly confirm if this is a known issue and if there are any plans to resolve it in an upcoming release?
Yes is an issue on the current version.
It will be fixed on the next 1.27 release.
Thanks for the information.
