Hi all
@BrianJ
After extruding, it is possible to divisions-offset-localz simultaneously I know it has been reported before
https://mcneel.myjetbrains.com/youtrack/issue/RH-49859
Example
Hi all
@BrianJ
Example
Yeah, this needs to eventually become a separate command, with options. Also ideally it would someday become a grasshopper component with all of it’s options available as inputs.
Thanks for the suggestion, it is similar to what I filed yesterday as https://mcneel.myjetbrains.com/youtrack/issue/RH-56109 . I think that one is probably more easily done since Extrude doesn’t support SubD yet nor does it allow division control of the result. Thanks for reporting this though, it made me notice Extrude is missing now in v7… I’ll figure out what happened.
Yes that’s right
Thanks a lot
