I tried to add some lines to Revit but with no luck.
I wonder why it doesn’t work…I remember it works before.
Add Line.gh (12.7 KB)
you need to explode your input curves before adding to revit
Oh, I thought it would accept “curves”, so it take lines only…
Thanks Mohamed
Hi @Jack_Zeng,
The component takes any curve that has no kinks. Arcs, Ellipses and Splines are supported.
I added this points and the tolerance value on the error message on 1.27.
