park
(Junghwo Park)
March 28, 2022, 8:49pm
1
Hi @Japhy ,
Cannot create grid when decimal number is odd number…
For example, it gives error to add grids when the value of number slider is 6.3 or 6.5 or 6.7 …
I am using Revit 2022 and RIR version 1.7.8 above.
20220328_Datum_Grid_Forum.gh (23.7 KB)
Thanks in advance!
Japhy
(Japhy)
March 28, 2022, 9:31pm
2
I believe you are getting a ‘Name must be unique’ error
You can modify how it’s handling the error here…
park
(Junghwo Park)
March 29, 2022, 8:47pm
3
Hi @Japhy ,
I have tried to use Continue option for the Error mode.
I still have the same issue…
Japhy
(Japhy)
March 29, 2022, 8:51pm
4
Try enabling Replace object tracking in this case, while moving your slider around. The error you are getting is in a duplicate name, correct?
park
(Junghwo Park)
March 29, 2022, 8:57pm
5
Yep… It is because of the duplicated name…
however, I would like to keep the same Revit ID by updating it because some of the dimensions or annotations are missing if I use “REPLACE” option.
kike
(Kike Garcia)
March 29, 2022, 9:05pm
6
Hi @park ,
The component turns orange to warn you about you are reusing an existing Grid but not a new one. Is this the message you get?
kike
(Kike Garcia)
March 29, 2022, 9:30pm
8
Hi again @park ,
After testing with your definition I see there is a problem with this component. It only works correctly on Replace tracking mode.
Keep looking to it.
park
(Junghwo Park)
March 29, 2022, 9:33pm
9
Hi @Japhy @kike ,
I get the same error “Name must be unique”.
I would like to use “Update” tracking method to keep the dimensions…
when I use “REPLACE” option… I get new grid with new Revit ID…
In this case, I lose my annotation…
kike
(Kike Garcia)
March 30, 2022, 6:19pm
10
Hi @park ,
We have fixed that problem and will be released on v1.6 next Tuesday or you can obtain it now on v1.7 from the Daily update channel.
park
(Junghwo Park)
April 4, 2022, 6:27pm
11
Hi @kike ,
That is great! Thanks very much for your help.
