Add Geometry DirectShape boot up problem
Hello all, I realized that loading a script with this component live, well it doesn’t like to be ready to go.
It corrects itself after a copy and paste of the component as you can tell by the screenshot.
Any opinions about that ?
Category input has a value? Try removing the non-essential inputs of name and material as well to try to narrow down the missing reference.
I had already tried all that, here’s a picture of the input we are missing.
Use Trigger component with lock enabled to control unwanted Revit transactions.
It’s not that
I misinterpreted your post with the additional button image. Can you provide files that we can look at? Thanks
It’s your
Revit import-export.gh (506.0 KB)
own code, nothing special here,
You didn’t internalize the geometry, I used a box and switched the Element Tracking to Replace then back to Enabled and everything seems OK.
Hi @thomas.lagarde,
There is a problem when some input geometry produce no output, this may happen when input is not valid o degenerated, like a mesh with no faces.
There is a fix on 1.14 to handle those cases gracefully.
Cool, I also played with the tracking mode feature and it took care of it. I didn’t dig enough that time.
