When adding dimensions it would be great if Rhino would accept enter as an indication to put the dimension on the points allready picked. I often want it in-place instead of offset.
Thanks!
Thanks!
Hi Jorgen - this would be the second point then, correct? if the snaps are not parallel to the dimension itself, there could be two answers depending on which point wins, is the problem I see…
Yes, or the first… Hm… another can of worms. I guess I don’t have a clear “do this always” answer to the programmers at this point, so better leave it alone I guess.
