I can´t seem to create a proper def, which can add diagonal lines if a polygon has more than 4 sides.
Here is an example geometry:
And here is what I aim to achieve:
Rhino file:
final.3dm (1019.5 KB)
Rhino file:
Seems so! Will test it out asap! Thanks!
In my case it does not do the job. Not always the U and V are under 90 degrees angle. So, as a start we have a set of intersected lines and we need to identify which ones form polygons with more than 4 corners.
def.gh (74.4 KB)
