Add detail in Layout only adds wireframe view
To make a useful drawing of a mechanical part, wireframe view is useless! Too many lines that make no sense in 2d.
But when I add detail, no matter what view is showing in a viewport (shaded, technical, etc) all that shows up in the detail is wireframe! THIS IS USELESS!
I at least need hidden lines to be dotted! But the geometry lines that show up in solids in wireframe are not acceptable in a drawing.
Is there any way to fix this?
People have been using Rhino successfully for several decades. Perhaps the problem is less with Rhino and more to do with your lack of familiarity with the program and your reluctance to prepare yourself to use it by perusing the tutorials and help that comes with the program.
@mrosenfield
You REALLY need to take the time to go through some Drafting tutorials.
We’ve linked them in other replies.
I have been using CAD for 40 years, so I’m familiar with the processes. I have been following the tutorials, and spent most of yesterday doing so, and trying different approaches.
So if you can point me to what I’m doing wrong, I’d be most grateful!
Michael Rosenfield
RSR Engineering, LLC
2420 E Hermosa Vista Dr.
Mesa, AZ 85213
480-861-6456
www.rsr-engineering.com
RSR Eng Logo small
Then my best recommendation for you is to leverage that experience, and skim through the User’s Guide to see how we do these similar tasks in Rhino.
When you find something odd or new, maybe do that tutorial.
The User’s Guide is the only free, self-paced, progressive set of general tutorials I’m aware of.
http://docs.mcneel.com/rhino/6/usersguide/en-us/index.htm
Cheers
I dug deeper into the drafting tutorial, and now I see where I was not thinking the way Rhino thinks.
I’m learning…
Thanks, John!
You’re very welcome.
Have fun with it.
John,
I am trying to create a drawing of a cross-section of my part - a steel bar with a hole in it.
I have tried Cplane and Mplane, and I can get the construction plane where I want it, but I haven’t been able to figure out how to generate a cross section of the part at either of these planes.
Can you point me to a tutorial on this, or help me get going in the right direction?
Thank you,
Michael Rosenfield
Mesa, AZ 85213
480-861-6456
RSR Eng Logo small
Hello - the Section command or ClippingPlane are what come to mind - depending on what you need as a result. Note Section uses a plane normal to the current CPlane. If you already have the CPlane where you want to make the section and you’d like the result to be some section curves (as opposed to a view) then start IntersectTwoSets as the first set, select the objects to section, and then Enter. For the second set, type IP and Enter then choose CPlaneXY as the plane. Then Enter.
Any luck?
Well, sort of.
I created the plane, and then the section, and now I have a group that is the section I want. I assume I can select the group, and change the properties to a new layer? Except that now the properties command doesn’t do anything! Used to work…. Did I turn it off, somehow?
So what I want to do is create a new detail that is the group, correct?
What am I missing here?
If I hit F3, or type Properties, no windows open with properties now. Used to work… Closed Rhino and reopened.
Here is the command history:
Command: _Properties
Command: '_Help
Command: Properties
1 polysurface added to selection.
Command: _CommandHistory
Command: _SaveAs
Successfully read file “D:\Data Test Equipment\Press Brake\Lower Die Support.3dm”
1 surface added to selection.
Any idea what is happening here?
Thank you,
Michael Rosenfield
Mesa, AZ 85213
480-861-6456
RSR Eng Logo small
