Hi
It is very efficient and has a Clayoo plugin
You can do this very easily yourself with 3 Picture(Frame)s. I suspect the plug-in only works correctly if the images are perfectly sized and scaled to each other first (in terms of pixels), whereas with 3 pictures you can scale each one independently in Rhino if need be. I use this pretty frequently.
Yes, I use it exactly, but it is much faster and more efficient
. Is it faster if you first have to fix the image?
I mean a lot of blueprints we can just paste their views into. Is this bad? There is even a script in 3DMax
If you have them, great. Most plans I found on the internet however are not properly scaled.
