I’m currently experimenting on how I can exchange information from rhino to python and the other way arround. So I was testing how to write a block instance into a 3dm file.
Here is what I coded so far:
Where check_block_in_file3dm(True, block_name, rhino_file3dm) is:
def check_block_in_file3dm(prev_success: bool, block_name: str, file3dm):
success = False
block = None
all_blocks = file3dm.AllInstanceDefinitions
for b in all_blocks:
if b.Name == block_name:
success = True
block = b
return(success, block)
The ‘block’ variable used is a valid InstanceDefinitionGeometry and the code runs without erros, but the 3dm file created has no objects in it. Any ideia on where the problem is?
I guess that I still don’t understand how to add InstanceObjects into a document.
Imo a better way would be to store every block as a single file and just insert each file as you need it. You can script the insert command or do it with rhino common.
Hello guys, I just now realised that I never gave you a followup to my issue.
Taking your advices, I manage to acomplish what I wanted, wich was to load all blocks from a reference file3dm into a target file3dm.
I’m sure that this will be helpful to someone in the future so here is how I did it:
def explode_block(
file3dm_objects: File3dmObjectTable,
block: InstanceDefinitionGeometry,
) -> IEnumerable:
Explode a block into its composing elements
Parameters
file3dm_objects
A reference file3dm containing the block to be exploded
block
A block to explode
Returns
block_elements
An Enumerable list of composing elements from exploded block
block_elements = List[Rhino.Geometry.GeometryBase]()
for obj_id in block.GetObjectIds():
if obj_id is not None:
obj = file3dm_objects.FindId(obj_id).Geometry
block_elements.Add(obj)
return IEnumerable(block_elements)
def load_all_blocks_from_file3dm(
file3dm_src: File3dm,
file3dm_tgt: File3dm,
) -> File3dm:
Load all blocks form a source File3dm into a target File3dm
Parameters
file3dm_src
A source file3dm containing all blocks to be loaded
file3dm_tgt
A target file3dm where the blocks will be loaded
Returns
file3dm_tgt
A modified file3dm with all blocsk loaded from reference file
Notes
For now, it only works with block that are not composed out of
other blocks
For that purpose it is necessary to add recurssion to function
all_blocks_src = file3dm_src.AllInstanceDefinitions
all_objects_src = file3dm_src.Objects
for block in all_blocks_src:
file3dm_tgt.AllInstanceDefinitions.Add(
block.Name,
block.Description,
Plane.WorldXY.Origin,
explode_block(
all_objects_src,
block,
return file3dm_tgt
