I’m a beginner.
I try to some ways, but the final result are two part after “merge”.
I don’t know what I should do.
Thanks in advance.
Top solid.gh (5.4 KB)
I’m a beginner.
Thanks in advance.
multipipe component creates subd geometry, u can not join it with other types of geometry (brep, mesh). you can use subd to mesh component, for example.
Top solid.gh (9.4 KB)
I made the fastest solution, just so that you understand the essence of the problem.
Also you can bake your geometry, and use ToNurbs command in rhino
ToNurbs works inside GH with plugin…
oh, thank you, i did not know that!
Thanks a lot.
But new question made again, after Bake, I want save as “igs” type. But it doesn’t work, warning shows contains “mesh”. I try to convert mesh to volume, it doesn’t.
What should I do?
I tried to use IAC plugin, can’t get right results.
Could you show me the flow?
Thanks a lot.
as I suspect, igs type is nurbs based, in that case you have to use breps for export. IAC ->>>
Thanks! It work.
Thanks again.
emm…
Your solution is effective.
But is a new question, the final result contains some imprecise geometry where the union(the connect) of two parts.
What do u have a idea to solve it?
btw - you don’t need a plugin to convert SubD to NURBS in Grasshopper - you can just connect a SubD parameter to a Brep component and it will convert automatically
Yes @DanielPiker, but it will not convert with options ?
Ok, You are reight, in this scenario no needed extra component
Thanks for your reply.
I want to konw why there are some imprecise geometry, and how does it come?
And why dose your latest solution can solve it?
Haha, sorry
I have so many questions…
Here another solution with MultiPipe with more tweeked settings.
Top_solid_X_Tweek.gh (18.1 KB)
Here another solution with Pipe
Top_solid_XPipe.gh (13.9 KB)
I have so few answers
