Actual bar diameter calculation
Hello, I am a beginner user of Grasshopper, I would like to automate the calculation of the actual diameter of the bars by increasing according to the table in the file.
Calculation_Nominal_Bar_Diameter.gh (5.9 KB)
](https://)
something like this might work
Calculation_Nominal_Bar_Diameter_re.gh (8.8 KB)
just be sure that each possible value in the slider is covered by a single domain
BRAVISSIMO!!! Perfetto grazie mille
You need add this function because between domains it return to the last one (+6)
you are 200% right, I have assumed the slider would always stay on “even integers only” like in the initial def :+1:
The second output N (Neighbor) choose the right index but in this case the domains are fixed.
there’s no possible slider position outside of the domains in the original file :+1: :slight_smile:
