Is there a way to activate the most recent used toolbar with a Rhino command or script?
I’ve been having some issues where my toolbars don’t come back when start Rhino, I put some commands in start up commands that gets most of them back, but not the MRU toolbar.
Hi James - if you show the MRU toolbar with only one Rhino open and close and re-open Rhino - does it stick?
It looks to me like there is not a good way to control this via a macro.
Normally it does stick, but for some reason that I haven’t been able to figure out, maybe 30% - 40% of the time when I open Rhino none of my floating toolbars or the floating command prompt are visible at all… they are all just shut off and whatever causes that also causes the MRU toolbar to be shut off. I have to go back into the settings and put a checkmark to turn it back on.
Only floating things are affected, toolbars that I have that are docked seem to always be restored. It happens often enough that I got tired of manually turning on my floating toolbars, so I put commands in startup to always turn them on, but I still have to go turn on the MRU toolbar.
