Is there any fast solution to select some element and activate it´s Layer?
Some script or something that will automatically activate the selected element layer?
Thanks
Thanks
If you are talking about making the object’s layer current, have you tried the _SetLayerToObject command?
(I think this command is poorly named, it should be called SetObjectLayerCurrent or something like that…)
–Mitch
Hi @Helvetosaur, that’s exactly it!!!
I 100% agree with you on that, the command is poorly named.
I looked around before posting because I was assuming that there should be a command for something like that.
Thanks a lot
Mad
