Action not being performed on all components of list-Grasshopper
Hello everyone!
I am trying to create kind of a bowl like shape on the corners of the bottom plate of my design. I used the trim solid feature, but I am baffled as to why the action is only being performed on two of the components and not all 6. I have been trying to solve this issue for a while now, and I have no clue what could be causing this.
Kresling 30,38 FINALVERSION.gh (22.4 KB)
the problem stems from the input of the Join component: it’s a tree with 12 different branches, and one item per branch
this means that the Join is executed 12 times, each time on a single object, on a different branch:
if -before the Join- you pass your data through a Merge component, the tree structure will be mantained:
Kresling 30,38 FINALVERSION_Re.gh (28.1 KB)
Thank you so much!! This was very helpful
