I have Acrobat 9. I couple of years ago I created 3D PDFs using another product. I exported t some format that Acrobat 9 could read (can’t remember which one).
Can Rhino export to a format readable by Acrobat 9? If so, which?
Test attached File
Ahh exported from Rhino but Win only (plugin)
TestPDF3D.zip (917.8 KB)
I think the plug-ins is Simlab Composer:
https://www.rhino3d.com/resources/4631
only sort-of related to the topic.
if you export .dae (Collada) from rhino, Preview.app will open it as a 3D/navigate_able model…
sort of similar to a 3d .pdf.
There is also another plug-in to export from Rhino to 3D PDF readable by Acrobat: https://www.rhino3d.com/resources/7399
Just to add to John’s recommendation - Simlab do a bespoke 3D PDF plugin for Rhino. It works very well and doesn’t cost as much as Composer. Worth considering if you only need a 3D PDF tool and not all the rendering functionality that comes with Composer:
http://www.simlab-soft.com/3d-plugins.aspx
so many goodies for windows…
…then join the Dark Side
but there’s still good in the mac rhino yet…
If you have photoshop you there’s a work around. You can save as an obj open it in photoshop and save that as a 3d PDF.
Thanks okeating!!!’ I didn’t know this!!
