Accessing parameter AsValueString not AsInteger
@Japhy
I am trying to access a parameter although the return Value is AsInteger, i need the AsValueString.
You’ll need to access that via scripting. What version of Rhino/Revit are you using?
I am using Rhino 7 / RIR : 1.21.8913.17015
you mean with element.WorksetId
Getting the .AsValueString is not recommended for certain workflows, what are you trying to do?
https://thebuildingcoder.typepad.com/blog/2019/04/batch-processing-and-aspects-of-asstringvalue.html#3
worked. thanks
Hi @pixypk,
RiR has ‘Element Workset’ and ‘Workset Identity’ for this case.
Does it work for you?
yes this works too, thanks i did not know this workset Node.
