Accessing light intensity map (Ray Traced data) via API
Hello :blush:
I am writing a C# code to get a light distribution/intensity pixel-wise map from a viewport or Rhino renderer.
  • From viewport with “RayTraced” option
  • Or through Rhino Rendering Pipeline with actual ray tracing calculation.
I can see V-ray has the feature (not sure if they have API sort of thing…) like below.
I wondered if I could access such data via API in Grasshopper C# component…
Obviously, Rhino calculates all values, but I haven’t been able to find a way to access to that data.
This is definitely possible, what would you do with this data? How would you like to view it?
– cs
Wow! Super glad to hear that this is possible.
What I am trying to do is generating some data for Deep Learning model that I want to train. Predicting light distribution from a single image input.
I don’t need to view, rather, I would like to get an array of calculated(by Ray Tracing/Global Illumination) light intensity per pixel.
Do you know which namespace/object I can access to that data from Rhino viewport or Rhino Rendering Pipeline?
And would you input a picture like above? Or would you have access to a rhino model?
I am using Rhino and Grasshopper. So I have access to model, viewport, and everything that Rhino manages.
I’d say you can definitely write a script to look at a bounding box and call for the view to temporarily be rendered in white with shading and a defined light source to test this out. I’ll try and write something when I have some spare time :blush:
– cs
