Accessing bool from public class Attributes_Custom in another class in order to bake
Hi everyone,
I am trying to access a bool created in my Attributes_Costum Class in my Geometry generating class in order to bake.
I tried so far to make a get property, since I thought that may be the problem:
public bool Bake
               get { return bake; }
I also tried making the bool public, but without success, it never appears to be possible to use that bool in the other class.
Here the complete code:
using System;
using System.Collections.Generic;
using Grasshopper.Kernel;
using Rhino.Geometry;
using GH_IO;
using GH_IO.Serialization;
using Grasshopper;
using Grasshopper.Kernel.Data;
using Grasshopper.Kernel.Types;
using Grasshopper.GUI;
using Grasshopper.GUI.Canvas;
using System.Windows.Forms;
using Grasshopper.Kernel.Attributes;
using System.Drawing;
namespace buttonTest
   public class buttonTestComponent : GH_Component
       public buttonTestComponent()
           : base("buttonTest", "Nickname",
               "Description",
               "Category", "Subcategory")
       public override void CreateAttributes()
           m_attributes = new Attributes_Custom(this);
       protected override void RegisterInputParams(GH_Component.GH_InputParamManager pManager)
           pManager.AddBooleanParameter("test", "t", "test", GH_ParamAccess.item);
       protected override void RegisterOutputParams(GH_Component.GH_OutputParamManager pManager)
       protected override void SolveInstance(IGH_DataAccess DA)
           Circle circle = new Circle(2.00);
          //here I want to bake
       public class Attributes_Custom : GH_ComponentAttributes
           public Attributes_Custom(GH_Component owner) : base(owner) { }
           protected override void Layout()
               base.Layout();
               Rectangle rec0 = GH_Convert.ToRectangle(Bounds);
               rec0.Height += 22;
               Rectangle rec1 = rec0;
               rec1.Y = rec1.Bottom - 22;
               rec1.Height = 22;
               rec1.Inflate(-2, -2);
               Bounds = rec0;
               ButtonBounds = rec1;
           private Rectangle ButtonBounds { get; set; }
           protected override void Render(GH_Canvas canvas, Graphics graphics, GH_CanvasChannel channel)
               base.Render(canvas, graphics, channel);
               if (channel == GH_CanvasChannel.Objects)
                   GH_Capsule button = GH_Capsule.CreateTextCapsule(ButtonBounds, ButtonBounds, GH_Palette.Black, "Bake", 2, 0);
                   button.Render(graphics, Selected, Owner.Locked, false);
                   button.Dispose();
            bool bake;
           public bool Bake
           public override GH_ObjectResponse RespondToMouseDown(GH_Canvas sender, GH_CanvasMouseEvent e)
               if (e.Button == MouseButtons.Left)
                   RectangleF rec = ButtonBounds;
                   if (rec.Contains(e.CanvasLocation))
                       bool bake = true;
                       MessageBox.Show("Hello World", "Hello World", MessageBoxButtons.OK);
                       return GH_ObjectResponse.Handled;
               return base.RespondToMouseDown(sender, e);
       protected override System.Drawing.Bitmap Icon
           get
               return null;
       public override Guid ComponentGuid
           get { return new Guid("20b81d57-ef4f-4ecf-973e-9c7caa9d24a8"); }
and the cs file:buttonTestComponent.cs (5.1 KB)
If someone may explain me I would be really grateful.
Baris
