Access rhinocommon & rhinoscriptsyntax offline?
Is there a way to download/access the information on https://developer.rhino3d.com/api/RhinoCommon/html/R_Project_RhinoCommon.htm and https://developer.rhino3d.com/api/RhinoScriptSyntax/ for when I’m offline?
I’ve seen a few topics linking to this page which gives me a 404:
https://developer.rhino3d.com/api/RhinoCommonWin/RhinoCommon.chm21
@stevebaer - is this something you can help with?
I believe your best solution for RhinoScriptSyntax is to simply download the repository. and add the folder to the system path in the editor.
for rhino common I would suggest if you use VisualStudio you can get all objects of an assembly by:
