Access Rhino args[] in a plugin (commandline parameters)
Hi!
Rhino can be started with commandline parameters, for example Rhino.exe /nosplash /runscript="-Grasshopper" etc.
Is it possible to access these parameters when a Rhino .NET plugin loads? I only found topics discussing the command field at the top of Rhino window.
public class MyPlugin: Rhino.PlugIns.PlugIn
    public MyPlugin()
           **// If Rhino was started with /nosplash, do nothing / do something**
    public static MyPlugin Instance
        get; private set;
    // You can override methods here to change the plug-in behavior on
    // loading and shut down, add options pages to the Rhino _Option command
    // and maintain plug-in wide options in a document.
    public override PlugInLoadTime LoadTime => PlugInLoadTime.AtStartup;
Have you tried System.Environment.GetCommandLineArgs?
https://docs.microsoft.com/en-us/dotnet/api/system.environment.getcommandlineargs?view=netframework-4.8
Damn, this never crossed my mind! It works great. Thanks!
